I have an USB 6363 (BNC) DAQ.
I see that USB-6363 is not officially supported with NI-DAQmx under any linux kernel/distribution.
I really would like to have it work with linux though. Is there maybe a workaround on how to make it work?
I tried with NI 2025 Q4 drivers on ubuntu 24.04.
I can see the DAQ both via lsusb and via lsni -v:
Bus 005 Device 008: ID 3923:75dd National Instruments Corp. USB-6363 (BNC)
System Configuration API Experts found: NI Network Browser 25.8 (network)
NI System Configuration 25.8 (nisyscfg)
System Configuration API resources found: /sys/bus/usb/devices/usb5/5-1
--Primary Expert: NI System Configuration 25.8
--Model Name: USB-6363 (BNC)
--Serial Number: 02113F99
But I cannot see it listed in the hardware configuration tool and I cannot connect to it via the python library.
Thanks!
