USB-6366: Recommendations for light barriers as triggers for data acquisition
I’m a student currently working with a USB-6366 DAQ device that uses BNC connectors.
I am interested in triggering data acquisition tasks using a light barrier and would like to know if anyone has experience using a light barrier in combination with a DAQ device.
Are there any light barriers you can recommend?
Are there any specific factors I should consider when selecting a light barrier that is compatible with a DAQ device?
Any advice or insights from those who have experience with this setup would be greatly appreciated.
Thanks in advance!
(423 Views)
The 6366 supports both analog and digital triggering. I have no experience with light barriers but one that outputs a digital state change can be used to trigger your DAQ. Use the PFI inputs on your device for a digital trigger.
(400 Views)
