USB-6509 setting clock speed
is the USB-6509 able to have the clock set? what is its fastest rate?
i got a message in matlab saying added channel does not support clock sampling.
Thank you,
Matt
(1,936 Views)
I am trying to toggle a ttl bit at 500 ns using matlab.
(1,923 Views)
The 6509 does not support hardware timing.  It can only switch at the rate your software is able to command it.  You need to use a High Speed DIO or an FPGA board to get the speeds you are asking for.
(1,909 Views)
just looking for that confirmation. thank you.
(1,887 Views)
