USB-8452 CS Polarity Control
I am using a USB-8452 SPI Module to as a MASTER to 7 UUTs.  In one test case, the Chip Select line needs to be Active HIGH (not default LOW).  Can the CS polarity be changed programatically in LabVIEW to be Active HIGH for a specific
SPI nCS line.
Thank you
Feras
(2,425 Views)
Hi, member
Does that mean you want to change the CS polarity Low -> High programmatically?
Check out this document, It describes basic SPI knowledge related to LV code. You can check out more examples of USB-8452 SPI in Help >> Find Examples in LabVIEW and search for SPI.
Also, if you want to select multiple UUT by CS line, you can refer to the document.
(2,341 Views)
