USB-8452 to Microwire EEPROM
I want to connect a M93S56 to the USB-8452's SPI (Microwire) interface to read and write to the EEPROM. I can take power from some other location for EEPROM and the WE/PRE lines can be made to be static to be pulled high and low.
How to I wire up this kind of configuration?
MonsterMunch
(1,856 Views)
Hello MonsterMunch,
Did you check this NI document
If not then go and open that from page 41 (from NI USB-8452) and go through it, there you can find description about setting up hardware and configuration.
Regards
(1,847 Views)
Thanks. I managed to get it work. Was simply confused how to connect this type of configuration. But we managed to get this to operate correctly.
Thanks again ;D
(1,835 Views)
