USB DAQ devices do not show up in MAX
Dave,
Can you obtain a MAX Technical Report? To do this, open MAX and go to File->Create Report..., then select Technical Support for the report type. Once you get that, please attach it here so I can take a look at it, thanks!
Justin E
National Instruments R&D
Message 11 of 24
(3,177 Views)
Report is attached
Message 12 of 24
(3,169 Views)
Hi Dave,
Thanks for attaching the report. A few entries in here look strange, so we're investigating into that right now. For the system used to generate that report, can I assume that you had 1 USB-6009 plugged in which shows up in Device Manager but not in MAX? You also mentioned you have one working system, where your USB-DAQ devices do show up properly. Can you also provide me with a technical report from that system, with a USB-6009 plugged in that does show up in MAX?
Justin E
Message 13 of 24
(3,137 Views)
The MAX report for the working station is attached.
Message 14 of 24
(3,121 Views)
Thanks Dave, we're still investigating into this right now. We'll keep you updated with what we find
Justin E
Message 15 of 24
(3,082 Views)
Hello Dave,
We have been investigating your issue and thus far determined which software components have interacted correctly with your hardware. However, we are still looking into additional areas of the DAQmx driver for possible reasons as to why some of the device information was not populated e.g. the USB 6009 Serial Number. Also, post an update regarding the status of this issue, thanks.
Ali M
Message Edited by Ali M on 05-11-2010 12:00 PM
Message 16 of 24
(3,013 Views)
I haven't gotten any further..
Message 17 of 24
(3,010 Views)
I got the same problem. I have an HP 8440p with Windows 7. The USB-6009 shows up correctly  in the device manager but is not recognized in MAX neither in Labview as an physical channel. I am trying to uninstall MAX to see if it helps. I have tested the USB-6009 at a different Lenovo laptop with Windows 7 as well. It works there!
Any news on the issue ?
Best regards Marius
Message 18 of 24
(2,768 Views)
There has been a NI-DAQmx patch released since the original post (Several actually)
Have you tried updating to the latest version?
Version 9.2.2 release notes says:
"Fix for the USB Interface Device issue discussed in KB 5DF9GJZL: Why Do Certain USB Interface Devices Prevent NI Devices from Appearing in MAX?"
Former Certified LabVIEW Developer (CLD)
Message 19 of 24
(2,764 Views)
Thanks frozen! It works now.
The 'NI update service'' pops up occasionally but it does not work. It just hangs forever. Maybe I would have received the patch automatically if it worked.
Best regards
Marius
Message 20 of 24
(2,741 Views)
