USB DAQ error after updating to DAQ 15.1
Everything was working well (DAQ 9.5) on my windows XP SP3 machine, so I thought it's a good idea to install the latest NI DAQ 15.1, now my USB DAQ has a red cross in NI MAX and does not work 😞
I tried re-installing NI DAQ 15.1, Rebooted PC, plugged the NIDAQ in and out, but the error remains.
Any ideas how to resolve this ?
(4,111 Views)
Hello morngoose,
First I recommend exporting your current MAX configuration:
http://digital.ni.com/public.nsf/allkb/0E0D3D7C4AA8903886256B29000C9D5A >
Then it sounds like you need to reset your MAX Configuration data, detailed in the following KB:
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9 >
Reset your system after these steps and that will hopefully work for you.
(4,068 Views)
Accepted by topic author morngoose
Thank you for the info. I tried the above, and un-installing and re-installing everything, but in the end the only thing that fixed the issue was to install a fresh copy of the OS, windows XP in this case.
(4,000 Views)
