USB NI-Daq 6361
Hi, I am using NI6361. I am transmitting 60 kHz signal with finite samples through AO. And receiving it through AI. My problem is i would like to repeat it frequently like: i should send 60 kHz of one period and receive it the same time. Then again after 5 seconds, it should repeat the same. Can anyone help me in that case? Thank you in advance.
Message 1 of 1
(2,985 Views)
