USB TC-01 Cold Junction Value
How can I determine the built in cold junction compensation of a USB TC-01 temperature module using C#?
and then enter that value in
myTask.AIChannels.CreateThermocoupleChannel("Dev0/ai0", "",0, 200, AIThermocoupleType.J, AITemperatureUnits.DegreesC, cjc value);
Curt
(817 Views)
You don't specify a value but a cjc channel instead.
myTask.AIChannels.CreateThermocoupleChannel("Dev0/ai0", "",0, 200, AIThermocoupleType.J, AITemperatureUnits.DegreesC, AIThermocoupleCjcSource.BuiltIn);
Reference:
https://tmesystems.net/
(779 Views)
Hi  Curt_C ,
According to the documentation (USB-TC01 Specifications - NI), your USB-TC01 module includes an integrated CJC sensor. You can specify the CJC value either by using the method described in the previous response or by manually entering a constant value if it is already known.
(733 Views)
