USB-analog output ground isolation
Does any USB based DAQ analog output deck has a isolated ground mode?
I have a circuit as below, in which the working voltage(15V-1V) can be controlled by USB-6008 DAQ analog output(0-5V). It works well in my laptop since laptop has a isolated ground, thus the DAQ works like a differential voltage supply. However, it could not work at desktop because DAQ share the common ground as the motor. I wonder whether there is any DAQ device providing the differential analog output (I know USB-6008 can not)? Or can any one help to give any idea in designing the circuit use USB-6008.
Thanks for your kindly help.
Best wishes for everyone.
Tony
(4,149 Views)
Here is one approach from OP Amps for Everyone
Make all R 10k and since you need 1-15V  the 15V single supply with a R2R output OP should fit.
It's not a diffential output, it's a diff in for your (ground refferenced) sink 😉
If that doesn't fit, take a look at full differential OPs.
Greetings from Germany
Henrik
LV since v3.1
(4,115 Views)
Handbook of OP amp applications
Edit timed out 😉
This Appnote seems to fit best ....
Texas Instruments, Differential Op Amp Single-Supply Design Techniques, SLOA072,
Henrik
LV since v3.1
(4,112 Views)
It is really helpful. My problem is solved by your method.
Thank you very much. Smiley Wink
Tony
^_^
(4,096 Views)
