USB cDAQ for fast point-to-point processing ?
i've written a application with LabVIEW that do fast point-to-point processing  (i.e. read one analog samples, do some processing and send the result on a analog output). On internal PCI or PCI-express card, i can reach around 1000 samples/s. Switching to a cDAQ USB system, i hardly reach 100 samples/s with many tweaks on the daqmx property nodes...Furthermore, the application become very processor consumming and sensitive to UI activites. Is this a real caveat with the USB bus (too many interruptions ?) or is there some means to have a high rate point-to-point USB transfert ?
All the best,
Vincent
(5,133 Views)
Hello Vincent,
What kind of PCI card did you used and what are the C series modules in you cDAQ chassis ?
Best Regards,
Thibault P
(5,106 Views)
For what you are doing, you might want to consider using an FPGA to do the processing and output directly on the module.  You can do this with a 9147 chassis.  You could then use an Ethernet connection to send data back and forth for your GUI.
(5,100 Views)
Thanks for the 2 answers.
I know the ultimate solution would be a FPGA based system (i already use some for other purposes), but i was just wondering about the possibility of using one of our cDAQ. I'm not aiming a truely real-time processing, just a moderately fast and reliable one, as the one i got with a internal PCI card.
About the C-modules i used, it's 9215 for input and a 9263 for output. I'm far from the max. rate specifications of theses modules, but i guess the highest rate is only reachable with N samples bloc transfert. Unfortunatly, this isn't the way i have to go.
Have a great day,
Vincent
(5,086 Views)
I haven't read the specs. Doors it support hardware timed single point acquisition. If it doesn't, then you are using software timed acquisition and you'll never achieve high rates.
(5,082 Views)
Hi Dennis,
yes i'm using software timed acquisition (single sample AI read and AO write in a timed loop), but as i said i don't want to achieve really high rates, but just try to understand why i can't get with the cDAQ approximatively the same rate i get with the PCI card. For now it's 10 times slower....
Vincent
(5,077 Views)
