USB fibre optic modems
I'm trying to use M-series DAQ boards (Usually NI-USB 6225) through USB fibre optic modems but I can't find a decent one.
They either don't work (can't find the device) or they are only USB 1.1 and I can't get the data throughput I need.
Can anyone suggest a USB fibre optic modem that works with NI M-series devices and at USB 2.0 speeds.
The DAQ board is going in a EM shielded enclosure.
Fibre optic is the only way I can get data in/out. It's powered by battery.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(2,990 Views)
Hi Troy,
National Instruments cannot recommend using anything in between the connection of the DAQ device and the computer. However, hopefully a customer will know of something that works for your situation.
Kind Regards,
Allie
(2,977 Views)
