USB protocol of the USB-6001
I've got a USB-6001, and would like to use it under Linux, preferably with the comedi library. Apparently for now neither the NI DAQmx (base) driver nor comedi support this device. All I could find was a special version for the raspberry PI, but as it's not open source, it only works on ARM processors.
Recently, the support for the USB-6501 was added to comedi (cf http://lxr.free-electrons.com/source/drivers/staging/comedi/drivers/ni_usb6501.c). If the protocol is similar, it would be very easy (for me) to add support for the USB-600x .
Do you have a document describing the USB protocol of the USB-6001?
(5,317 Views)
Hi Pieleric,
I haven’t been able to find the protocols for the USB-6001. Could you try adding the support for the comedi library and just see if it works as expected? There is a chance the protocols are the same.
Unfortunately the USB DAQ Device series are still unsupported in Linux: https://www.ni.com/en/support/documentation/supplemental/18/windows-vs-desktop-linux-daqmx-experienc...
However you could try the most up to date DAQmx Base drivers (if you haven’t already), although the USB-6001 is not listed as supported on this:
https://www.ni.com/en/support/downloads/drivers/download.ni-daqmx-base.html#326059
Sorry I couldn't help further.
Pete
Certified LabVIEW Architect
(5,290 Views)
