USB6008 - Problem changing voltage range on an open voltage channel using C#
I have an application that requires two difference voltage ranges on a single voltage channel. I'm using C# and I can't find how to clear an existing voltage channel and re-open it with a different range.
Thanks in advance!
(3,357 Views)
Accepted by topic author TimBledsoe-Lync
Found it...
TaskAIChannels.AIChannels.All.RangeHigh = high;
TaskAIChannels.AIChannels.All.RangeLow = lo;
(3,355 Views)
