USB6008 and PWM to control heat element
Hi all,
I nee a little assistance with a project im completing. I have to control the temperature of a heating element using PWM.
When i have the hardware sorted out i will be trying to create a labview PID program to control the heating element around a desired setpoint.
Here is the basic list of components i am using and i will attach a rough diagram to show how i have them connected up.
1. NI USB-6008
2. 12Vdc  PWM controller  http://www.dhgate.com/12v-24v-3a-dc-motor-speed-control-pwm-hho/p-ff808081317fdb680131821f26066bcb.h...
3. SSR Crydom EL Series Solid State Relay 100Vdc, 10A
4. 35Vdc heating element
I have done some research on the forums here and understand that using theUSB6008 for PWM is a non-starter. So I want to use a analogue output from USB6008 as an input into the PWM control board and then ill be able to adjust the duty cycle using a dial. This PWM controller will then be used to switch the SSR, turning the heat element on/off.
The issue i currently have is that this controller will not function with the analogue output from DAQ. I realise that the USB6008 only supplies an output voltage max of 5v, so i need some suggestions of how to boost the analogue output voltage so it can power this controller.
Any suggestions will be much appreciated
(5,152 Views)
An IC known as an "op amp" will amplify voltages... wiki's got a great article on them.
(5,149 Views)
Hi Duff79,
An op-amp would allow you to boost the voltage from the USB6008, as SnowMule said.
What is the PWM controller expecting from the USB6008? Will a certain voltage give a certain result from the PWM board?
Ben B.
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
(5,127 Views)
The idea is to use a thermocouple to monitor temp of heat element. I wanted to control the heating element with Pwm but using Pwm control board instead of labview as usb6008 not ideal. I want to be able to select a set point and then reach set point and stable state as quick as possible. Not sure wether to use analogue or digital output to "power" Pwm controller. I need a 12v for Pwm controller input for 12v Pwm output which is used to switch a SSR.
I have used a 528 Op amp as suggested and this has powered board but from some reason the Pwm signal is between 8 and 12v.
Thanks for help so far.
(5,116 Views)
I am currently tackling a similar task. I set up a heat tank to maintain a desired temperature, monitored by a thermocouple, fed into PID inside LabVIEW, then its output is used to 'Generate Signal' inside LabVIEW to make PWM signal, which toggled an SSR connected to a heat tank's heating element. I didn't use a external PWM controller, since LabVIEW was able to make the PWM signal. I got it working up to +5, -3 degrees to my set temp. The overshoot was asymmetrical due to the asymmetrical heat capacitance, so I hooked the dt out from PID control to use different PID variables when its heated up then cooling down, resulted little better set temperature. Since its a heating element, with very slow response (my gain was 35~45), it was little hard to nail it compared to mechanical element. I used LabVIEW 12, with compactDAQ 9485 (SSR) and 9211 (thermocouple) in 9174 chassis.
(4,670 Views)
