USB6008 connection Raspberry Pi
Hello everybody,
i am new here and also i am new with an raspberry pi. for a project i get an old system running with the usb6008 as the connection between thinkpad and the temperature measurement. My task should be: to replace the thinkpad notebook for an raspberry pi 3.
I tried many ways to install and connect the usb6008 at the raspberry, especially i used this site:
https://forums.ni.com/t5/NI-Labs-Toolkits/Low-Cost-USB-DAQ-Driver-for-use-with-Raspberry-Pi/ta-p/353...
but it doesn´t work. there is no connection. could you give me help please. first if it´s possible to run the system with raspberry pi and usb6008!? and how!?
the system actually works with the ni daqmx 18.6, is this maybe the first problem?
and will i have to install a ni daqmx at the raspberry? because i needed it also when i tried the old project at my thinkpad.
would be great if you could help me.
best regards...
Message 1 of 1
(2,464 Views)
