Ultimus 1 analog input/output via 8 pin DIN cable to DAQ usb6341
I am new to labview and need some help connecting an nordson ultimus I to a usb 6341 Daq. I control on/off by the 8 pin connector coming from the utlimus I the DAQ. So far I have been able to read the voltage on the input channel and monitor the voltage on the output channel but not completely control it by start stop. When the 8 pin connection touches both the input and output ports, the air dispensers starts but does not stop. My goal is to have a program that starts and stop the air dispensers on demand. Any help would be appreciated.
(2,951 Views)
Are you trying to programmatically start/stop the device or are you sending a signal to it from the USB-6341?
Marco C.
Applications Engineering
(2,905 Views)
Yes.
I recently purchased Nordson Ultimus V as a digital air controllers, is there way to build VI from the older program that was created for the Ulitmus V back in 2009?
(2,885 Views)
Can you elaborate more on what you mean by older program? Does your device come with a driver from the manufacturer made for LabVIEW?
Marco C.
(2,875 Views)
You can use the driver from that page to generate your own VI in order to operate your device. In most cases, the driver files should be documented with instructions on how to use it as well as best programming practices.
Marco C.
(2,854 Views)
