Unable to answer my Question
Look im not being funny but I wouldnt have to post across multiple threads if someone would just answer the question I posted, which was, how fast can the digital lines on the DAQPad 6015 toggle high and low. If I wanted alternative methods to controlling the system I would ask for them. If you dont know the answer to the question dont feel bad about it ,just dont reply .Solution continuim..........hahahaha
good daySmiley Mad
(3,004 Views)
In case you lost the spec that came with the device, you can view it https://www.ni.com/docs/en-US/bundle/370969b/resource/370969b.pdf. In there, it states a max transfer rate of 250S/s but it is system dependent. The digital I/O is software timed which means that it is also highly dependent on how you have written your program. In any case, the 500 Hz you mention in another post as the speed you want, doesn't seem possible.
(2,982 Views)
Thanks for that.......ive now changed the application of my project to something that requires less speed........sounds like a copout but I was running out of time. Anyway, thanks again, I do appreciate all the inputSmiley Indifferent
(2,959 Views)
