Unable to communicate to BNC-2110 using PCI-6251
Hi all,
I am experiencing a similar, though not identical, error to that discussed in the thread “Selecting BNC-2110 Connector Block as an accessory” (5-27-2010). I recently upgraded our lab’s version of LabVIEW and have lost the ability to communicate to the BNC-2110. Here are the basic hardware/software specs I am currently working with:
OS: Windows XP Professional, 5.01.2600, Service Pack 3
LabVIEW: 2010
Accessory: BNC-2110
Board: PCI-6251
CVI Run-Time: 9.1.0.428
NI-DAQ: 7.4.4f7
NI-DAQmx Device Support: 9.1.5f1
NI-DAQmx ADE Support: 9.1.5
NI-DAQmx MAX Configuration: 9.1.5
I’ve been using the example code “Write Dig Chan.vi” found under Hardware Input and Output>DAQmx>Digital Generation> as a test to insure the problem is not within my own code. When I run this code I receive the error:
Error –201003 occurred at DAQmx Create Channel (DO-Digital Output).vi:1|
“Device cannot be accessed.”
When using MAX I can see the PCI-6251, labeled “Dev1.” I can also see the BNC-2110 as an option under the Accessory tab in its properties. However, I receive the same error in the vi (-201003) irrespective of whether “None” or “BNC-2110” is selected as the accessory for PCI-6251. Additionally, when I try to set the power-up states of the BNC-2110’s digital outputs in MAX I receive a similar error:
Error –88705 occurred at daqmxcfg_DAQmx Get Power Up States (Digital) Remote.vi:1
“The specified device is not present or is not active in the system.”
To the best of my knowledge the BNC-2110 is properly connected (directly using the SHC68-68-EPM and the green power light is on). My device manager indicates that the PCI-6251 is installed and running properly. Additionally, the system automatically recognized the BNC-2110 after the LV upgrade and reinstalled the proper drivers and indicated no error.
I would not be surprised if I am missing some obvious fix to this problem but I’ve been stuck here for two days and would appreciate any help that might point me in the right direction.
Chris
(3,899 Views)
Hi Chris,
My hunch is that the NI Device Loader is not running.
If you run a self test on the device, does it also fail with error -88705?  If so, the device loader may not be started.  Here's how to check.
Jon S
(3,879 Views)
Thank you Jon S,
I appreciate it. I found another solution that worked prior to reading your message so I'll attempt to fill you in with what I know and what I did. First, before I found a solution, I could not run a self test on the device. In MAX I could right click on the 'NI PCI-6251' under 'Devices and Interfaces' in the tree, but only the options 'Device Pinouts,' 'Properties,' 'Help,' and 'Self-calibrate' were available. All others where grayed/disabled. Additionally, there was a small red 'x' in the lower right-hand corner of the NI PCI-6251 icon in the MAX tree. Also, depending on what properties I tried to change, MAX would crash entirely and I'd have to restart it.
After poking around some more I did arrive at a solution that worked. I found R Sandoval's response to the thread "Re: Patch Released for NI-DAQmx To Address an Issue Where Devices Don't Show up in MAX" on this board where he addresses possible MAX database corruption. I used the corruption removal tool he linked to and it worked perfectly. I am now capable of communicating as expected to the BNC-2110. Again, thank you for your help.
Chris
(3,866 Views)
