Unable to write TDMS channel properties from for loop
I created a simple DAQ & Storage VI to learn about TDMS. One of my priorities was to write custom properties for file, groups, and channels. I was able to get most everything working except the channel properties. The set properties VI is inside a for loop and the channel name and property values are auto-indexed. I kept getting errors (-2500 I think). After many changes, I discovered that the TDMS Set Properties VI does not like 'sub-arrays'. It will work with exactly one channel, only. If you can't use a for loop, then how would you write channel properties for 2 to n.. channels, especially with a high channel count and if the count always varies?
Phillip Neir
GM Engineering
(3,181 Views)
Phillip,
this is a known issue with 8.20 that will be fixed in the very next LabVIEW release. The good news is that there is a workaround. You can turn any subarray into a regular array by wiring it in and out a for loop, with both input and output being indexing tunnels. You can then wire it to the TDM Streaming functions with no problem.
Hope that helps,
Herbert
(3,177 Views)
Thanks Herbert. It does indeed help.
Phillip Neir
GM Engineering
(3,173 Views)
