Unknown status code: -200090 from nidaqmx
I am recceiving this error when I try to list the devices I reserved from the python library.
Failed to get extended error info. DAQmxGetExtendedErrorInfo returned error code -200090.
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/usr/local/lib/python3.12/dist-packages/nidaqmx/system/_collections/device_collection.py", line 75, in __len__
    return len(self.device_names)
  File "/usr/local/lib/python3.12/dist-packages/nidaqmx/system/_collections/device_collection.py", line 93, in device_names
    val = self._interpreter.get_system_info_attribute_string(0x193b)
  File "/usr/local/lib/python3.12/dist-packages/nidaqmx/_library_interpreter.py", line 3454, in get_system_info_attribute_string
    self.check_for_error(size_or_code)
  File "/usr/local/lib/python3.12/dist-packages/nidaqmx/_library_interpreter.py", line 6479, in check_for_error
    raise DaqError(extended_error_info, error_code)
nidaqmx.errors.DaqError: Failed to retrieve error description.
Status Code: -200090
where can I find the definition of this status code ? does anyone knows what it mean ?
thanks.
(67 Views)
According NI-DAQmx Driver Error Codes
Error -200090
Shared library was not found. This error might be the result of an inadvertent deletion of an NI-DAQmx component. Reinstall NI-DAQmx, or download the latest version of the driver from the National Instruments website at ni.com. If the error is still returned, contact NI Technical Support.
https://tmesystems.net/
(39 Views)
Thank you ZYOng for your prompt response.
out of curiousity: which libraries do we need to have installed to be able to fix the Status Code.
(28 Views)
