Unstable voltage sampling of usb-6210
I have a USB-6210 and I use it to get lithium battery voltage. As shown in the picture,it performs well in the beginning of sampling. But after a while, the fluctuation of the sampling voltage will suddenly increase.VoltageData.jpg
I want know what happened and how to solve this problem, Could anyone help me? By the way, I have checked the sampling wires connection and changed the sampling channel, but none of these worked.
Yao.
(2,222 Views)
HI, have you tried measuring anything else besides the battery?
Does the deviation continue to rise or it stays in range as in attached picture?
(2,045 Views)
Keep in mind that the fluctuation is only increasing by +/- 0.002 V, which is pretty small for many purposes.
You might get some insight by looking at that "noise" in the frequency domain, perhaps it isn't random.
-Kevin P
(2,034 Views)
