Update value of a frequency channel
I have created a frequency task channel by using DAQMX function (DAQMXCreateCIFreqChan) using one counter. With a timer I read the value every 0.05 sec.
That works fine but I get a new value only every +/- 0.15 sec. Is it possible to get a value refreshed every 0.05 sec even if the accuracy decrease ?
Also, the accuracy of the value is good by multiplied by two. It's not really a problem but if you know the reason?
Thanks for your help.
(3,154 Views)
Hi Gzen,
First one, it seems you are not working with LabVIEW. Which program are you working with? Measurement Studio for VB, C#, C++, .NET ?
Second one, it seems that you are not giving a timing inside your program. Am I correct? And the problem you mentionned above could appear! Let's me explain : If you are not providing time in your programmation. The program will execute your code as fast as possible un-regarding of your User Interface refresh ! Most of the CPU will be taken by the execution of your code and when your CPU has the possibility, it updates/refreshes the User Interface.
Third one, for the value multiply by two, I don't know what happens to your program... Smiley Sad
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(3,122 Views)
Dear Julien,
Thanks for your reply.
Sorry I forget to give much information. It’s programmed in VB6 and I’m using the DAQmx API. The card is a DAQPAd 6015.
The code for the frequency channel is the following:
-DAQmxErrChk DAQmxCreateTask("", taskhandle2)
-DAQmxErrChk DAQmxCreateCIFreqChan(taskhandle2, "DEV1/ctr0", "", 2, 50000, DAQmx_Val_FrequencyUnits3_Hz, DAQmx_Val_Edge1_Rising, DAQmx_Val_CounterFrequencyMethod_LowFreq1Ctr, 0.05, 4, "")
In a timer (at 0.05s) I use the following:
-DAQmxErrChk DAQmxReadCounterScalarF64(taskhandle2, 0.01, dataF, ByVal 0&)
In the same time I have a second task using the analog channel configured like this:
- DAQmxErrChk DAQmxCreateAIVoltageChan(taskHandle, "Dev1/ai0", "", _DAQmx_Val_Cfg_Default, 0, 10, DAQmx_Val_VoltageUnits1_Volts, "")
- DAQmxErrChk DAQmxCfgSampClkTiming(taskHandle, "OnboardClock", 20, DAQmx_Val_Rising, DAQmx_Val_AcquisitionType_ContSamps, 1)
And I do the following items in a loop :
- DAQmxReadAnalogF64 taskHandle, numSampsPerChannel, 10#, fillMode, data(0), arraySizeInSamps, sampsPerChanRead, ByVal 0&
- Doevents (to allow the timer to refresh the frequency value)
- I save the value of the analog channel and frequency channel into memory.
When test is finished (max 10sec), I save the values from the memory to a file. For the analog channel there are no problems, just for the frequency channel, I get the value change only every three data.
Greg
(3,110 Views)
