03-30-2005 11:31 AM
04-28-2005 03:07 PM
04-29-2005 11:56 AM
06-09-2005 07:43 PM
07-28-2005
11:45 AM
- last edited on
07-16-2024
10:46 AM
by
Content Cleaner
NI-DAQmx 7.5 (link below) now supports the USB-6008 and USB-6009 devices on Windows. I strongly recommend installing this much more powerful and robust driver. For more information on how to switch your device to use NI-DAQmx, refer to the KB linked below.
NI-DAQmx
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
KB: 3NE7GJMY
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIRDCA4&l=en-US
07-29-2005 11:16 AM
08-01-2005 08:21 AM
I have been looking through this thread and I can see there are many people at different stages of using the USB-6008 product. I would recommend that anyone having trouble with DAQmx Base takes a step back and updates the driver to DAQmx 7.5 as recommended by Jeremy C above.
Once you have done this and restarted your PC, you should be able to simply go into Measurement & Automation Explorer (MAX) and switch over the driver to DAQmx as described in the KB. This will then bring up an installation box where it asks you to install the firmware for the USB-6008 for DAQmx. Go through these steps and allow it to install, then refresh MAX and it should then appear under DAQmx Devices.
From then on you should have no problems using it as a normal DAQmx device with the examples in LabVIEW. I have just run through all of this on my machine here as I was writing this e-mail to make sure I get everything right, and I had no problems what so ever.
Hopefully it will be the same for you.
Peter Horn.
Applications Engineer.
NIUK.
08-01-2005 02:26 PM
08-02-2005
05:11 AM
- last edited on
07-16-2024
10:48 AM
by
Content Cleaner
Hello everyone,
It sounds like you have solved the problem with the error 200220, but in case you want some more information about this, I have found a few links which should be useful to you.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DeCHSA0&l=en-US
Hope this helps,
Peter H.
NIUK
08-02-2005 08:30 AM
