Usb-6343 incorrect AI signal
Usb-6343 measuring 6v at terminals but daq reads .05
(1,134 Views)
How did you connect the signal? AI+ and AI- along with resistors to AGND? did you configure the DAQmx task to use Diff or SE based on how you connected the signal?
Santhosh
Soliton Technologies
(1,128 Views)
We are using a GE Druck Pressure transducer that has direct voltage out on two wires.  so we have Analog input (+) from the sensor wired to terminal 1, analog input (-) wired to terminal 2, and terminal 3 is wiring to ground. I am not aware of the need to wire in a resistor when i have voltage input, so maybe thats my problem, but all my other usage of this DAQ has had consistent DAQ reading with multimeter sampling at the DAQ terminals.
(1,091 Views)
See Table 1 of Field Wiring and Noise Considerations for Analog Signals
https://tmesystems.net/
(1,079 Views)
