Usb 6366
Currently I am using two usb 6366 cards for analog input (all 8 channels of each card simultaneously at 2MSa/sec./ch ).  Now I wish to enhance the number of channels by adding another 2 usb 6366 for analog input at same sample rate
 Whether adding more cards will effect the rate at which the data can be sampled and saved in computer and data loss will take place as 4 cads will now have to save data using usb to computer.
(1,338 Views)
You may use PCI-express - USB card (more than x4 bandwidth)
'USB Host controller card'
(1,286 Views)
If you need the best reliability and utmost bandwidth, you can use PCIe or PXIe cards.
Santhosh
Soliton Technologies
(1,279 Views)
