Use 6733 to send AO and read AI?
I have a 6733 board and I want a way to sweep the voltage output of the Analog outputs and look at the output from one of the analog inputs.  In truth I need only some way to make the analog inputs work.
Any suggestions.
Kevin
(3,034 Views)
Do you know the spec of the card you are working with? It doesn't have any analog inputs.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,024 Views)
Thanks Adnan, I found another board (not sure which one it is, maybe 6070) and it has analog inputs.  I will try that and I will probably have another type of question related to that later.
Kevin
(3,016 Views)
