Use DAQmx 8.8 installation with LV2012
I want to use DAQmx 8.8 with LabVIEW Version 2012. I downloaded the DAQmx drivers and installed them. But when I start my VI, LabVIEW can't find the DAQmx related VIs (e.g. start task, clear task...)
Can anybody help?
Thx in advance
Manuel
(3,431 Views)
You can't use such an old version. Why don't you simply install the latest version of DAQmx?
(3,428 Views)
I want to use the NI USB-6525 digital I/O module to control valves in an ALD system. My code is working in principle but for short switching times I get an error: "Write to task called more frequently than device can safely allow" or something similar. From another post I learned that this problem can be solved by using DAQmx before Version 8.9. I know that this error occurs because switching the relays more frequently than 5Hz at 90% duty cycle could cause physical damage to the I/O lines. So I know that using an older Version of DAQmx would be on my own risk but I need to achieve switching times around 100ms and less.
Thanks for your reply and hoping for further help
(3,424 Views)
You need to link to this other post. You should also attach a snippet of your code and the actual error code.
In any case, you cannot use the older versions of DAQmx.
(3,422 Views)
Hi Denis,
The error code is -201278:
"Possible reason(s): Consecutive writes to a digital line occurred more frequently than the device can safely allow." The other post I mentioned can be found here: http://forums.ni.com/t5/Digital-I-O/NI-USB-6525-Error-201278/m-p/1097522/highlight/true#M12598
I also attached snippets of the code I am using but I think this won't help in this case.
If you are sure I can't use this DAQmx Version with LabVIEW2012, I will delete it and use LabVIEW 8.x instead...
Thanks again for your reply!
Sincerely,
Manuel
(3,410 Views)
According to this kb, the last LabVIEW version that can use DAQmx 8.8 is LabVIEW 8.6.
(3,402 Views)
