Use M-Series cards with DAQmx in Matlab!
I am trying make a communication between Matlab and my NI-USB6221 card.
Here is my Matlab code :
loadlibrary('nicaiu.dll','nidaqmx.h','alias','myni')
taskh1=uint8(1);
[a,b,taskh1] = calllib('myni','DAQmxCreateTask','master',taskh1)
I precise that the files 'nicaiu.dll' and 'nidaqmx.h' are in the Matlab workspace (so I don't have to use addpath). And I don't have Data Acquisition Toolbox.
And this is what I get :
Warning: Warnings messages were produced while parsing.  Check the
functions you
intend to use for correctness.  Warning text can be viewed using:
[notfound,warnings]=loadlibrary(...)
> In loadlibrary at 381
  In dll_nidacmx at 6
??? Error using ==> loadlibrary at 461
There was an error loading the library "C:\Documents and
Settings\uidt1982\Desktop\CARTE_NI\nicaiu.dll"
La procédure spécifiée est introuvable.
Error in ==> dll_nidacmx at 6
loadlibrary nicaiu.dll nidaqmx.h
Caused by:
    Error using ==> loaddefinedlibrary
For the ones who doesn't speak french at all, the phrase in bold means : "the specified procedure cannot be found"
I don't understand this error and I am really stuck...
Some help would be welcome.
Message 101 of 106
(1,961 Views)
OK, it works today...
In fact, it seems that my lib file was not recognized
Message 102 of 106
(1,980 Views)
Hello, I want to generate an executable program using Matlab.
This executable will use DAQmx functions to acquire analog data for instance.
There is no problem with creating the executable. I build including "nicaiu.dll", "NIDAQmx.h", "NIDAQmx.lib", and all others functions needed.
But, when I want to run the executable, here is the response from Matlab :
"C:\Users\...\Windows\System32\nicaiu.dll"
Undefined function or variable 'myni_proto'.
How can I fix it ??
Message 103 of 106
(1,919 Views)
Nobody ??
Message 104 of 106
(1,896 Views)
I am having the same problem as you except I am not looking to create an excecutable progrma in matlab. When I try to run the folowing piece of code:
I get loads of errors such as :
Warning: Warnings messages were produced while parsing. Check the functions you intend to use for correctness. Warning text can be
viewed using:
> In loadlibrary at 344
Warning: The data type 'error' used by function DAQmxGetTaskAttribute does not exist.
> In loadlibrary at 403
Warning: The data type 'FcnPtr' used by function DAQmxRegisterEveryNSamplesEvent does not exist.
Warning: The data type 'FcnPtr' used by function DAQmxRegisterDoneEvent does not exist.
Warning: The data type 'FcnPtr' used by function DAQmxRegisterSignalEvent does not exist.
Warning: The data type 'error' used by function DAQmxGetChanAttribute does not exist.......
I'm not sure what I'm doing wrong I guess there is a fundamental problem with the nicaiu.dll? It's very unusual because yesterday I used the same line of code and got a different error which was the one you had in your first post. How did you get matlab to recognise your library?
thanks,
Alan
Message 105 of 106
(1,836 Views)
64 bit Matlab (2015a or 212b) crashes every time I try to create a task with NI-DAQmx Base 14.0. Surprisingly, 32 bit Matlab (2010a) seems to work fine. Any ideas how to solve the problem with 64 bit Matlab?
Here is a simple way to replicate my error. Load nidaqmxbase from Ni-DAQmx Base 14.0 library. Then call DAQmxBaseCreateTask.
Example code:
loadlibrary('/Library/Frameworks/nidaqmxbase.framework/Versions/14/nidaqmxbase', ...
            '/Applications/National Instruments/NI-DAQmx Base/includes/NIDAQmxBase.h', ...
            'alias', 'nidaqbase');
task0 = libpointer('uint32PtrPtr',0);
calllib('nidaqbase','DAQmxBaseCreateTask','',task0);
Here is Matlab's crash dump:
Configuration:
  Crash Decoding      : Disabled
  Crash Mode          : continue (default)
  Current Graphics Driver: Unknown hardware
  Current Visual      : Quartz
  Default Encoding    : ISO-8859-1
  Host Name           : new-host-2.home
  MATLAB Architecture : maci64
  MATLAB Root         : /Applications/MATLAB8.5.app
  MATLAB Version      : 8.5.0.197613 (R2015a)
  OpenGL              : hardware
  Operating System    : Darwin 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
  Processor ID        : x86 Family 6 Model 70 Stepping 1, GenuineIntel
  Virtual Machine     : Java 1.7.0_60-b19 with Oracle Corporation Java HotSpot(TM) 64-Bit Server VM mixed mode
  Window System       : Quartz
Fault Count: 1
Abnormal termination:
std::terminate()
Register State (captured):
  RAX = 0000000054b0786c  RBX = 0000000122255a50
  RCX = 00007fcb1fa180d0  RDX = 0000000054b07820
  RSP = 0000000122255300  RBP = 0000000122255620
  RSI = 00007fcb1dce1b00  RDI = 0000000132265000
   R8 = 00007fcb1dce7910   R9 = 0000000054a204e6
  R10 = 00000001322bb000  R11 = 00007fcb240253e0
  R12 = 0000000000000000  R13 = 0000000000000000
  R14 = 00000001136bd420  R15 = 0000000000000000
  RIP = 000000010ffad8ab  RFL = 00007fcb2406a370
   CS = 0000000054b07db0   FS = 0000000132687000   GS = 00007fcb2406a4a0
Stack Trace (captured):
[  0] 0x000000010ffa8964 /Applications/MATLAB8.5.app/bin/maci64/libmwfl.dylib+00031076 _ZN2fl4diag15stacktrace_base7captureERKNS0_14thread_contextEm+00000052
[  1] 0x000000010ffac02b /Applications/MATLAB8.5.app/bin/maci64/libmwfl.dylib+00045099 _ZN2fl4test17terminate_handledEv+00000763
[  2] 0x000000010ffabac7 /Applications/MATLAB8.5.app/bin/maci64/libmwfl.dylib+00043719 _ZN2fl4diag13terminate_logEPKcPK17__darwin_ucontext+00000119
[  3] 0x000000010fa17f9b /Applications/MATLAB8.5.app/bin/maci64/libmwmcr.dylib+00380827 _Z32mnRunPathDependentInitializationv+00002875
[  4] 0x000000010fa18217 /Applications/MATLAB8.5.app/bin/maci64/libmwmcr.dylib+00381463 _Z32mnRunPathDependentInitializationv+00003511
[  5] 0x000000010fa17908 /Applications/MATLAB8.5.app/bin/maci64/libmwmcr.dylib+00379144 _Z32mnRunPathDependentInitializationv+00001192
[  6] 0x000000010fa17384 /Applications/MATLAB8.5.app/bin/maci64/libmwmcr.dylib+00377732 _Z22mnInstallCrashHandlersv+00000420
[  7] 0x00000001134b41d1                           /usr/lib/libc++abi.dylib+00147921 _ZSt11__terminatePFvvE+00000008
[  8] 0x00000001134b3c5b                           /usr/lib/libc++abi.dylib+00146523 _ZN10__cxxabiv1L22exception_cleanup_funcE19_Unwind_Reason_CodeP17_Unwind_Exception+00000000
[  9] 0x00000001132c8fa1                           /usr/lib/libobjc.A.dylib+00057249 _ZL26_objc_exception_destructorPv+00000000
[ 10] 0x000000011204a12d /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation+01380653 -[NSObject(NSObject) doesNotRecognizeSelector:]+00000205
[ 11] 0x0000000111fa5272 /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation+00705138 ___forwarding___+00001010
[ 12] 0x0000000111fa4df8 /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation+00703992 _CF_forwarding_prep_0+00000120
[ 13] 0x000000013b6ff6af /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+13133487 _ZN19MainLoop_MacCocoaUIC2Ev+00000095
[ 14] 0x000000013b6ff73c /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+13133628 _ZN19MainLoop_MacCocoaUI4InstEv+00000060
[ 15] 0x000000013b7e2dea /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+14065130 WSendEvent+00000250
[ 16] 0x000000013b7e3f8f /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+14069647 WCreateEx+00000543
[ 17] 0x000000013b7e420e /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+14070286 _ZN8WMgrCore10InitializeEv+00000254
[ 18] 0x000000013b793790 /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+13739920 _Z12InitManagersiPKPKcPiP14MGAppInterfaceP16MGUIAppInterfaceS0_+00000512
[ 19] 0x000000013aabbb53 /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+00273235 _Z10MGMainInitiPKPKcPb+00000179
[ 20] 0x000000013aabbf84 /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+00274308 _Z6MGMainiPKPKc+00000132
[ 21] 0x000000013aabcaed /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+00277229 _Z11SysUIThreadPv+00000013
[ 22] 0x000000013b854e9e /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+14532254 _Z15ThreadCoverProcPv+00000094
[ 23] 0x000000011385d899            /usr/lib/system/libsystem_pthread.dylib+00006297 _pthread_body+00000138
[ 24] 0x000000011385d72a            /usr/lib/system/libsystem_pthread.dylib+00005930 _pthread_struct_init+00000000
[ 25] 0x0000000113861fc9            /usr/lib/system/libsystem_pthread.dylib+00024521 thread_start+00000013
Message 106 of 106
(1,560 Views)
