Use MATLAB Simulink with USB-6009
I tried some work with USB-6009 using Simulink.
The version of my MATLAB is R2008a.
However, analog input block size is fixed by 2.
Why should be 2?
I couldn't understand.
(6,182 Views)
NI-DAQmx requires at least two samples for clocked acquisition.  There are additional simulink blocks that were introduced in R2008a to allow single sample acquisition and generation.
-Rob
Rob Purser
Manager, Test and Measurement
MathWorks
rob.purser@mathworks.com
(6,175 Views)
What the clocked acquisition means?
I don't understand why two samples are obtained in a one sample time?
If 2.1 and 2.3 were measured, what is the truth?
And what are the additional blocks for single sample acquisition?
Could you introduce an example?
(6,163 Views)
 I've attached a picture of the blocks I'm talking about.
All the best,
-Rob
Rob Purser
MathWorks
(6,149 Views)
