Use cDAQ-9135 like cDAQ-9178?
Hi community.
I have a cDAQ-9135 but my CPU power and memory requirements exceed its limit.
Looking at the block diagram I fear the answer is "No", but maybe there is a way to interface with the cDAQ modules mounted in the cDAQ-9135 from a PC?
Ideally I could use the 9135 like a CDAQ-9178, but any "workaround" suggestion is welcome.
BR,
nimich
(1,118 Views)
Dear nimich,
There is no way of doing it with this cdaq. It is already old and I suggest you buying new cDAQ as this one will not be even supported soon.
best,
anasei.
(990 Views)
