Use rear connector of SCXI-1520 as an input?
Good morning,
Regarding connectors on the SCXI-1520, is it possible to use the rear connector as a 68-pin input (instead of an output)?
I have the following hardware and wanted to know if it's feasible to pipe a signal from an SC-2345 to a PC through the path below.
NI SC-2345 (Signal Cond. Block)  --> NI SCXI 1520 (Universal Strain/Bridge) via 68-pin cable   -->  NI SCXI 1600 (USB Digitizer Card) --> PC
(2,908 Views)
Accepted by topic author hma1
Hello hma1,
Unfortunately you will not be able to do that.  The only "input" would be when taking in signals from cascaded chassis.
ColeR
Field Engineer
(2,887 Views)
