Using 3rd party Multifunctional DAQ Boards with LabVIEW Evaluation?
I have a Keithley Metrabyte DAS-1802ST Data Acquisition Board installed on my computer. I am experimenting with LabVIEW 6.0 Evaluation and would like to know if it is possible to use this as a LabVIEW Device in this version. I have the DriverLINX (Driver software for the Board) configured to recognize the board as a LabVIEW Device but can't seem to locate it in LabVIEW. Hope to hear from you soon. Thanks Charlie
(2,654 Views)
You should be able to use 3rd party boards with LabVIEW Evaluation just the same as any other version. You just need a driver and a set of LabVIEW VI's that call that driver. Other than that, I don't know how the Keithley software works. Hope this helps!
Russell
(2,654 Views)
