04-14-2009 11:15 AM
I need to excite a shaker by sending Signal from my application.
I am trying to use PCI 6221 card for this purpose. I will be connecting the signal coming from my DAQ card to a power amplifier and then to shaker.
I will be sending a sine wave or sweep sine wave with noise without noise.
Any suggestions on this?....can i go-ahead with this card?
Please let me know if someone has already done with this kind of application.
Anil
04-14-2009 11:40 AM
Anil-
Whether you should go ahead or not would depend on the answers to questions you haven't asked. Primarily it will depend on the power amplifier being compatible with the 6221. You don't say what voltage range is required as input to the power amplifier, or the input impedance/current requirement for the power amplifier. You also don't address the question of the waveform frequency you require, though if this is a physical shaker (like sieve shaker?) it is unlikely to require a frequency higher than the 6221 can generate.
Any suggestions will also depend on whether you are writing your application in C/C++, or using Labview, or something else.
Good luck with your project!
04-14-2009 12:19 PM
Hi John,
Thanks for your quick reply.
I am using LabVIEW for programming.
This is a physical shaker. and i need 0-10V . Do we need to check any other thing?
waveform frequency range would be upto 4 KHz and i need continuos output waveform when i select Sine wavefrom. or a sweepsine with some finite duration (for ex: 30 sec)
Anil
04-14-2009 12:32 PM
The PCI-6221 can certainly do 0-10V, and it's unlikely that the power amplifier will overload the analog outputs.
You should be able to get 4 a 4 kHz waveform as long as you're not too greedy with the number of output points per cycle.
As for examples, I'm afraid I'm not a Labview user- I do all my DAQ programming in C++. Hopefully someone else will offer something. Probably you should start by looking at the various waveform generation examples. I know there are quite a few that ship with NI-DAQmx, and I think Labview makes it pretty easy to access them. You can probably use on of them as the start for your own application.
04-15-2009 12:22 PM
