Using DAQ PXI_Trig
Chassis: NI PXIe-1078
DAQ: NI PXIe-6363
According to MAX, I can send trigger from PXI_Trig 0-7 to PFI 0-15. Can I send trigger from PXI_Trig 0-15 to AO, AI, Dig pins?
Thank you
(3,505 Views)
Hi areksuroboyo,
When you say according to MAX are you referring to the Device Routes?  This will give you all possible options for routing signals and if anything is not listed it is not possible for this card.  You can send the trigger to the Pause Trigger or Start Trigger for those lines but can not directly output the signal off of an AO pin.  Your PFI lines are the only ones that can export these signals.
Kyle S
Regional Account Manager
NI
(3,491 Views)
