Using DAQ from National Instruments
Hi, I am looking to read analog input readings using USB-6353. Does this have python support for automated logging? If so, I have installed nidaqmx but receive an error about not being able to load "nicaiu" module. I am using python 3.9 and would like to use this.
Message 1 of 8
(2,717 Views)
I did download the hardware package but now see the error raise DAQError or DaqError(error_buffer.value.decode("utf-8"). I have tried running the following code:
import nidaqmx
with nidaqmx.Task() as task:
    task.ai_channels.add_ai_voltage_chan("Dev1/ai0")
    task.read()
Message 2 of 8
(2,651 Views)
I have downloaded hardware package and now do not see nicaiu missing module error. Can someone point me to link where I can read python analog voltage example? I get raise DAQerror when trying to add ai voltage chan on Dev1/ai0.
Message 3 of 8
(2,685 Views)
Please provide all the missing information.
OS, bitness, DAQmx driver version, programming language etc.,
Santhosh
Soliton Technologies
Message 4 of 8
(2,663 Views)
Hi, OS is windows 10/64 bit system and programming language is Python with visual studio. I downloaded DAQmx using pip install nidaqmx and have version 0.6.4 ,NI-DAQmx Python API
I am running python code on this page: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Pf1SAE&l=en-US
But see daq error with error code Hex 0x80040301
Message 5 of 8
(2,637 Views)
The problem may be there is no name assigned to device as you can see in image attached above. How to add name?
Message 6 of 8
(2,613 Views)
Looks like DAQmx driver is not installed (not just the Python package). Did you install DAQmx driver from https://www.ni.com/en-us/support/downloads/drivers/download.ni-daqmx.html#460239 ?
Santhosh
Message 7 of 8
(2,595 Views)
Hi, yes that was installed
Message 8 of 8
(2,592 Views)
