Using DAQmxIsTaskDone
My previous posting seems to have developed into a different related question.
Using the ANSI C example program TwoEdgeSep.c. In my application I want to measure on both counters of a USB 6210 so I am interested in starting both counters and then waiting for the counter tasks to finish, and then reading the results.
To test this out on a single counter I added the following loop:
// code before here is as the original example
//apart from bool32  Yes; declaration
 // DAQmx Start Code
 DAQmxErrChk (DAQmxStartTask(taskHandle));
 loop:    DAQmxErrChk (DAQmxIsTaskDone(taskHandle,&Yes));
         if(Yes==0)
                goto loop;
// code after here is as  the original example
 // DAQmx Read Code
 DAQmxErrChk (DAQmxReadCounterScalarF64(taskHandle,30.0,&data,0));
 printf("Measured Pulse Width: %.9f sec\n",data);
I tested this without the loop and put in a 1 sec pulse onto the default inputs and it worked fine.
If I enable  the loop then the program stays in it for  ever, however many pulses I put in. I think this means that the task is never done. I get the feeling that the counter is not ARMED  until the call the Read function but I cant see a way of doing that earlier.
Looking for help
Martyn Eccles
Message 1 of 1
(3,198 Views)
