Using MCC DAQ with Labview
Hi
has anyone used MCC's USB analog DAQs with labview? Does it work well?
(5,415 Views)
I have no experience with MCC's HW or SW.
But, MCC hardware ships with a CD that has libraries for LabVIEW.
See:
http://www.measurementcomputing.com/download.htm
I believe NI acquired MCC 1-2 years ago.
(5,407 Views)
AnalogKid is correct. MCC’s USB analog DAQ boards can be programmed with LabVIEW. It is not as intuitive as programming an NI-DAQ board but it can be done and it works. There is a Universal Library for LabVIEW CD that should have come with your MCC board. If you don’t have it you can download it from the following link:
http://www.measurementcomputing.com/cbicatalog/cbiproduct.asp?dept%5Fid=259&pf%5Fid=1360&mscssid=WH6P0GM2Q7U19H6LWM8RJ1CR979N11F1
If you have LabVIEW questions feel post on the forums, otherwise if you have hardware questions feel free to contact MCC about them. Have a great day!
Ima U.
Ima
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(5,390 Views)
Thank you for replying to my query. I have downloaded the software and looking into using it for the MCC board.
(5,386 Views)
You are welcome. I wish you the best in your application.
Ima
(5,383 Views)
