apologies for the delay.
The error is usually down to a bad install of NI-DAQ.
Can you post your code here, so I can try it on my machine, and then we should be able to narrow it down to a PC / Install / Driver issue.
One thought is that you're trying to access the driver from a couple of places at once, and this is causing a problem :
When you attempt to use NI-DAQ 6.x (or 7.x Traditional) from multiple applications or in conjunction with other NI hardware drivers, NI-DAQ may fail to load if it is unable to acquire the necessary resources.
The usual recommended solution is to migrate to the new NI-DAQmx 7.x driver where this issue has been fixed, however, your 6533 is currently only supported under the Traditional portion.
Otherwise, to resolve this issue using NI-DAQ 6.x or 7.x Traditional, proceed sequentially through the following list of possible solutions. After trying each solution, attempt to reproduce the issue. If the issue has not yet been resolved, proceed to the next solution in the list.
Shut down all applications that are using NI-DAQ (examples include MAX, LabVIEW, Measurement Studio, Visual Studio). Now try loading your applications in a different order - in particular, try loading the application that gave you the error first.
Update to the latest version of NI-DAQ.
Update to the latest versions of all other National Instruments drivers used by the target system.
Download the palBase utility attached below to your Windows folder, C:\WINDOWS for Windows 95, 98, ME, or C:\WINNT for Windows 2000 and XP. The palBase utility allows you to fine tune the way that NI-DAQ acquires resources from the system by making changes to both the drivers and the registry.
To execute the palBase application from a DOS command prompt:
a. Go to the Start menu and select Run.
b. Type command and press Enter.
c. In the command prompt window, type palBase -b 64000000 -s 44000000 and press Enter.
d. Reboot the system and try your applications again. If the issue is resolved, you may delete the palBase utility.
Repeat 4. This time, at the command line, type palBase -b 44800000 -s 45800000
Repeat 4. This time, at the command line, type palBase -b 32800000 -s 36800000 -d 18400000
Repeat 4. This time, at the command line, type palBase -b 33400000 -s 35400000 -d 34400000
If the issue remains, or if palBase reports an error, please contact National Instruments Technical Support at the link below.
To restore your system to default values, open a DOS command prompt as explained in Option 4 above, type palBase -b 64000000 -s 0 -d 21000000, and press Enter
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer
