Using NIDAQ API's to get info on virtual channel setup
Need to be able to retreive info about virtual channel settings (enumerate virtual channel names and get info such as help text etc) that were set up using the MEX tool.
(2,993 Views)
Hello;
Unfortunately, there is no NI-DAQ functions that access the information on the virtual channels.
Regards
Filipe A.
(2,993 Views)
OK - Is there any way at all to get access - i.e. other libraries/components?
(2,993 Views)
Yes moto, here I attached a program for you to use, you can access the information for the channels.
XD Gao
Applications Engineering,
(2,993 Views)
Thanks, however is there any way I can do the same thing programmatically from a C++ application (I am using Visual C++)?
(2,993 Views)
hi moto, I checked on the Visual C++ side, at least for now I did not see a function that goes out to read the virtual channel settings in MAX, what you could do though, is to build a DLL in LabVIEW and introduce this DLL in Visual C++, but don't forget to include the LabVIEW runtime if you do it.
XD Gao
(2,993 Views)
