Using PCI-6722 Analog output with Traditional NI-DAQ 7.1
I am having trouble configuring a virtual channel for my PCI-6722 Analog output card. I am using LabView 6.1 and Win 98. The card works fine in Measurement & Automation when i use the Test Panels to generate voltages. However, in Labview, i get an error. Also, in 'Data Neighborhood' in MAX, when i try to configure a Traditional NI-DAQ Virtual channel, my DAQ card does not show up in the list of DAQ Hardware to be used.
I cannot use NI-DAQmx to configure a channel as i do not have LabView 7.x.
Is there a way to use the 6722 with Traditional NI-DAQ or is it only supported by NI-DAQmx?
(2,919 Views)
The PC_6722 is a DaqMx only card, and therefore requires LabView 7.X, and it will not run under LabView6.1 (DaqMx runs under LV 7.x or higher)
(2,912 Views)
Thank you Dr. Imad!
Additionally, you all can find answers to all such questions at the following website:
http://www.ni.com/support/daq/versions.htm
Anuj D.
(2,886 Views)
