Using Traditional NiDAQ 7.1 to read 6025E with 5B01 and five 5B37
My goal is to continously read 11 analog input channels for 80 seconds and save the data to a file. Each analog input channel would be operating at 1KHz.
I am using Traditional NiDAQ 7.1 along with Visual C++ 6.0 on a Windows 2000 machine.
I am also using a 6025E DAQ with a 5B01, three 5B37 modules and eight 5B38 modules.
I have read through and executed several NiDAQ examples.
I am having difficulty deciding what example to use as a starting point.
I considered the AIOnePoint example, however it does not use the 6025E's internal timing to specify the sampling frequency and it only reads one channel at a time (seems inefficient for my goals).
I considered the DAQDoubleBuf example,
which uses internal timing for the sampling rate, but it only reads one channel at a time.
Therefore, I am assuming that I need a program the SCANS multiply channels at once and uses internal timing to achieve a sample rate.
Can I use double buffers with multiply scans?
Do you have any example code?
Does the pseudo code below make sense?
// Code
AI_Configure()
DAQ_DB_Config()
DAQ_Rate()
SCAN_Setup()
SCAN_Start()
while(< 80sec)
if(DAQ_DB_HalfReady())
DAQ_DB_Transfer()
SaveBufToFile()
DAQ_Clear()
Please help 🙂
Tree
(2,583 Views)
Tree,
Your analysis of the proper manner of implementing this functionality is correct, and your pseudo-code is quite complete. I would suggest that you combine two of the examples to complete your application. As you mentioned, the DAQdoubleBuf.C example demonstrates how to design a continuous application that is both hardware-timed and buffered. The SCANsingleBufAsync.C example demonstrates how to use the SCAN functions to perform a multi-channel acquisition.
Good luck with your application.
Spencer S.
(2,583 Views)
