Using USB-6251 DAQ as a Power Supply
I'm trying to figure out how to use the DAQ as a DC power supply. I tried using Signal Express to create an Analog Output, but it won't allow the Min./Max. values to be the same.
Any ideas?
(3,463 Views)
Min/Max values are used to set up the expected range of output voltages.  If you ever want to be able to turn the output voltage off ( 0V ), I suggest that you set the MIn to 0 Volts.
Just remember that the 6251 is not going to be able to source a lot of current.  About 5mA max acording to data sheet.
Message Edited by centerbolt on 02-15-2008 02:49 PM
(3,454 Views)
Please realize that the DAQ card analog ouput current is limited to +/-5mA, you can't power too many devices with that.
Here's the specs:
https://www.ni.com/docs/en-US/bundle/371291g/resource/371291g.pdf
Edit: Centerbolt, I belatedly saw you already mentioned this fact
Message Edited by AnalogKid2DigitalMan on 02-15-2008 12:53 PM
(3,444 Views)
Analog Kid,
Don't worry about it.  It was important enough to be mentioned twice.  Once for each ear.  Smiley Very Happy
(3,439 Views)
