10-28-2012 12:19 PM
Dear Friends,
I have an USB based data acquisition module with 8 I/Ox configured to measure and monitor certain parameter like Temp,Pressures,switch functional etc. With this, I would like to utilize our Labview 8.6 version for measuring & monitoring and control purposes.
Would any one of you guide us how to go ahead with the third party(other than NI-products) products to be used with our Labview pl. !
Regards ,
KCPadhy,
For KICSPL,B'lore-93,
Contact:9916133982,
E-mail: kanhupadhy@gmail.com
10-28-2012 01:48 PM
10-29-2012 05:39 AM
Dear Mr Dennis_Knutson,
I thank you for your reply.
Further Info:
I am using a PIC-18K50 MCU IOx.I have connected some sensors to the IOx to monitor their outputs. I would like to capture these analog out_put data in the "Serial vi Front Panel" of your Lab View. As such I am using IAR Embedded workbench/MPLAB/WIZ-C. With this information may I request to further interact & suggest pl.
Kanhu
10-29-2012 06:02 AM
Dear Sir,
There was an typographical error in the MCU info. Pl.read PIC18k50 as PIC18F14K50 MCU.
Kanhu
10-29-2012
09:49 AM
- last edited on
06-16-2026
03:53 PM
by
Content Cleaner
Further Info:
Kanhu
It's YOUR LabVIEW since you are the one that is writing the program.
How you connect still depends on your choices. If you install a windows driver for the USB that emulates a serial port, then the connection will appear in MAX as a com port and you can proceed from there. If you want to use USB RAW, then you create your own VISA driver by following the instructions here [link removed; article no longer available].
