Using an acoustic transducer with USB-6212
Hello everybody,
I have an acoustic transducer and the USB-6212. My objective is to use the USB-6212 to send a signal to my transducer using the NI-DAQmx software to play the sound. Since, i've been trying a lot without results i would appreciate it if someone could explain the process in detail since i'm not very knowledgeable of this kind of equipment.
Thanks in advance.
(2,202 Views)
Hello aqua207,
The best way to learn how to use one of our equipment is by looking at the proposed examples:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kK9ySAE&l=fr-FR
You will find a large library of optimized examples done by R&D.
If you are not using LabVIEW, you will find plenty of topics on internet presenting sample codes you could adapt:
https://stackoverflow.com/questions/18229196/ni-usb-6211-reading-analog-voltage-input
Have a very nice day 🙂
Armando
(2,166 Views)
