Using an external voltage signal to end while loop
Hi!
I would like to use an external voltage signal (generated by the user) to end current running while loop. How can I do this?
The external trigger device is a foot switch which the user presses when he wants to end the while loop. The foot switch generates a known voltage when pressed.
There are multiple while loops, each of which has to be controlled by this foot switch. Some whie loops are nested.
I am using PCI-6034 (with CB-68LP), LV-PDS 6.1, NI-DAQ 6.2
Thanks in anticipation,
Gurdas
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
(2,988 Views)
Gurdas,
The method you use will be dependent upon the signal coming from the foot pedal. If it's a digital signal, you can compare the value using the boolean functions. With an analog signal, you can use a peak detector VI or a level detector VI. Based on whether the condition is met, you can wire in a stop to the terminal in the while loop. Good luck with your application.
(2,988 Views)
Thanks Sarah!
The method you describe is what I have in mind but I don't know how to implement it.
To be specific:
1) Which pins on my PCI-6034 should receive the signal from the footswitch? Specify for both a digital signal and analog signal. For analog, I would like to avoid using the usual AI pins. Is there a pin that is meant for just this type of requirement?
2) How do I read this signal and use it as a trigger? My vi uses AI config, start and read. I would prefer to NOT use these to read the status of the footswitch. It would be nice if there is a fucntion that only reads the status of the line/pin to which I have connected my footswitch.
- Gurdas
(2,988 Views)
