Using "Custom Voltage with Excitation"-Task on DAQPad-6259
you do not need to connect the sense outputs.
You can wirte the value of the Voltagesource at the excetation field in the DAQmx Task.
This will cause a scaling with this voltage.
This excetation value will not be measured.
Plamen
National Instruments Germany
Application Engineer
Message 11 of 11
(881 Views)
