Using sample clock with digital input
I'm trying to use a sample clock with a digital input, but I keep getting the error "Error -200077 occurred at Property Node DAQmx Timing"  with possible reasons being that the requested balue is not a supported value for this property..
Does anyone know how to fix this issue?
(4,885 Views)
What DAQ device are you using? Look at the specs and see if the digital I/O is software timed. If it is, then you don't have s clock and must not use the DAQmx timing function and just write a single value at a time in a loop. This will result in s low rate with considerable jitter.
(4,874 Views)
I am using a myDAQ...I just checked the specs and it says that it is software timed.
(4,866 Views)
You might be able to get 1kHz. Anything faster will require different hardware.
(4,858 Views)
