Using task_handle in callback of register_every_n_samples_acquired_in_buffer(..., callback) - non homogeneous to task = nidaqmx.Task(...)
Again on callback topic (note that I am posting in HW forum where I have already seen python code snippets while nothing seems to match in SW boards. Maybe there could be a SW board about nidaqmx-python)
  • I store all the tasks I am creating: task = nidaqmx.Task("Task_" + device.name); all_tasks.append(task)
  • in my callback I try to match 1 of these tasks with the task_handle (def callback_nidaq(task_handle, every_n_samples_event_type, number_of_samples, callback_data))
  • testing task._handle == task_handle did not work, I ended up doing task._handle.value == task_handle
When I dump both handles, I get: task._handle: c_void_p(138902160250752) task_handle: 138902160250752. So it explains why task._handle.value works
Why is it not homogeneous ? Is it intended to be used as I am using it (at least in C API, I guess yes) ? nidaqmx-python is a front-end to C libs so I understand handles as ctypes but don't see why task_handled is not ctype
(640 Views)
Accepted by topic author ft_06
As discussed in other threads, task_handle can be answered through functools.partial like callback_data. Above method works but NI uses internally partial. In my case:
def callback_nidaq(task, task_handle, every_n_samples_event_type, number_of_samples, callback_data):
    # task is the task referred by task_handle so no need to use task_handle
When configuring the tasks:
for task in all_tasks:
    task.register_every_n_samples_acquired_into_buffer_event(xxx, functools.partial(callback_nidaq, task))
(592 Views)
