VI not updating DAQ readings correctly
I am using a usb-6009 to acquire a DC voltage from a pressure transducer. My vi runs a loop that averages N data points of the voltage per loop and then displays the average on the front panel. When it cycles through the next loop, it then averages the next N data points and displays the result. Here's my problem: if I change the DC voltage to a new lower value, even after some time, the front panel continues to report voltages on the order of the original voltage. I would like the front panel to update an accurate voltage reading in real time (well, after every N points). I've been stuck on this issue for some time and getting to the end of my rope. I suppose it is probably a simple vi programming issue as I still am pretty new to LabVIEW. I'll attach my vi.
(2,781 Views)
Duplicate post
(2,767 Views)
